After examining the returned main bearings with a number of A&P mechanics and going through all the other information with them and other experienced mechanics, I a feeling better about of my engine. Here are some of the conclusions we have come up with.
The knocking sound created when pulling on the prop could be the result of the heat expansion characteristics of an aluminum crankcase vs. steel main bearings and crankshaft. My reasoning behind this is;
1. It only happens after the engine has been heated to operating temperatures
2. A Lab analysis of the oil showed no significant metal contaminates. There was less metal in the latest analysis than the previous oil analysis.
3. The increase of axial leverage put on the crankshaft when pulling on the end of one prop blade (which is not normal for the engine) in combination with the increased clearance between the main bearings and crankcase bearing seats (due to heat expansion) could cause a normal tapping sound to be amplified into a knocking sound.  This was the thoughts of a couple other mechanics that had run across this situation in other engines. The unknown issue is whether or not the clearance continues to remain in spec during operating temps which I assume they are.
4. The main bearings were also examined by a couple of aircraft mechanics which told me that the wear pattern of the removed bearings was typical for opposed cylinder engines. I measured the worn area of the bearing against the non-worn areas and there was no measurable difference in the thickness which means they were good. No grooves in any kind were found on the bearings.
5. ULPower also said that there was a bluing effect on the bearing which they contributed to running the engine hot. According to the mechanics that examined  the bearings, none of them could see any signs of overheating. I’ve also tested my instrument probes in boiling water and they are calibrated correctly, so I’m not sure where ULPower came up with this  “overheating” conclusion.
6. During the 10 hours of flying which I knew of the knocking sound, I never once noticed any unusual sounds in flight, issues with oil temp or pressure, vibration or power loose of any kind.
The oil line fitting fix looks like a much better configuration then the previous bubble flare (which was the stress point that failed). They have also gone to softer seamless steel  tubing for the assembly which in combination with the new fitting should eliminate any stress points in the assembly.
The thrust bearing assembly is holding up good, no leak from the front hub since it was redesign to apply double the preload on spring washers. ULPower stated that there was some wear on the spring washers which they claim could only happen if i was running a loose hub.  Not only did I verify the torque on the hub 4 times during the 150 hours of flight, I also verified it just before returning the engine to ULPower. I feel this is incorrect becasuse there was no wear on the end of the hub which seats to the end of the crank shaft and if the hub had a loose hub that area would also show wear and it did not.  The only other conclusion is that the pre-load in the thrust bearing assembly needs to be increased slightly.
Only time will tell on how this engine will do in the market so I am going re-install the engine and fly the crap out of it
 . I will keep the forum posted of my progess.
Traduction par Google (merci à ceux qui le peuvent de éditer et peaufiner) :
Edité et peaufiné par diabolo jusqu'au point 3 inclus.
Après avoir examiné les roulements principaux renvoyés avec un nombre de mécaniciens A & P et passant par toutes les autres informations avec eux et les autres mécaniciens expérimentés, j'ai un meilleur sen timent au sujet de mon moteur. Voici quelques-unes des conclusions auxquelles nous sommes arrivés.
 Le cognement créé en tirant sur l'hélice pourrait être le résultat de la différence de dilatation thermique entre un carter en aluminium avec des paliers principaux et le vilebrequin en acier. Sur cette base, mon raisonnement est le suivant:
1. Il arrive seulement après que le moteur a été chauffé à des températures de fonctionnement
2. Une analyse de laboratoire de l'huile n'a montré aucune quantité importante de métaux contaminants. Il y avait moins de métal dans la dernière analyse que dans l'analyse de l'huile précédente.
3. L'augmentation de l'effet de levier axiale mis sur le vilebrequin en tirant sur la fin d'une pale (qui n'est pas normal pour le moteur) en combinaison avec l'augmentation de distance entre les paliers principaux et sièges de roulement de carter (due à la dilatation thermique) pourrait provoquer un bruit anormal amplifié sous forme de cognement. Ce fût la pensée de quelques mécaniciens qui ont rencontré ce problème sur d'autres moteurs. L'inconnue reste de savoir sir cet espace demeure dans les tolérances avec les températures de fonctionnement, et je suppose que c'est le cas.
4. Les paliers principaux ont également été examinés par un couple de mécaniciens d'aéronefs, qui m'a dit que le motif de l'usure des roulements enlevé était typique des cylindres opposés. J'ai mesuré la zone usée de l'appui contre les zones non usés et il n'y avait pas de différence mesurable dans l'épaisseur ce qui signifie qu'ils étaient bons. Pas de rainures en tout genre ont été trouvés sur les roulements.
5. ULPower également dit qu'il y avait un effet bleuissement sur le roulement dont elles ont contribué à faire tourner le moteur chaud. Selon la mécanique qui a examiné les roulements, aucun d'eux ne vois aucun signe de surchauffe. J'ai aussi testé mes sondes instrument dans l'eau bouillante et ils sont calibrés correctement, donc je ne sais pas où ULPower venu avec cette "surchauffe" conclusion.
6. Pendant les 10 heures de vol dont je connaissais le son frapper, je n'ai jamais remarqué aucun des sons inhabituels en vol, des problèmes avec le temp d'huile ou de pression, de vibrations ou d'alimentation débranché de toute nature.
 La solution en ligne d'huile raccord  ressemble à une configuration beaucoup mieux alors l'arrondi bulle précédente (qui était le point le stress qui a échoué). Ils ont également allé à tubes sans soudure en acier doux pour l'assemblée qui, en combinaison avec le montage de nouvelles devrait éliminer les points de stress dans l'assemblée.
 Le palier de butée  se maintient bien, pas de fuite du moyeu avant car elle a été la refonte d'appliquer le double de la précharge sur rondelles. ULPower a déclaré qu'il y avait une certaine usure sur les rondelles dont ils prétendent ne pouvait se passer si je courais un hub lâche. Non seulement ai-je vérifier le couple sur le hub 4 fois au cours des 150 heures de vol, je l'ai aussi vérifié juste avant de retourner au moteur de ULPower. Je pense que c'est becasuse incorrecte n'y avait pas d'usure sur la fin du moyeu qui sièges à la fin du vilebrequin et si le hub a un hub perdre ce domaine serait également montrer l'usure et
 ne [/ u] . La seule conclusion est que la pré-charge dans le palier de butée doit être légèrement augmenté.
Seul le temps dira comment ce moteur va faire le marché, alors je vais ré-installer le moteur et voler la **** hors de lui: D. Je vais garder le forum posté de mes de progrès.
