Le lien vers leur site:
http://www.aircraftkits.com.au/
PERFORMANCE Hirth 3701 ES
Take off/rotate speed(no flaps)
40 kts
Takeoff Distance, zero wind, no flaps
70m
Takeoff Distance, zero wind 15 degrees flap
40m
Takeoff Distance, light headwind no flaps
40m
Takeoff Distance, light headwind 15 degrees flaps
10-30m
Cruise Speed
82 kts
Top Speed (Rotax Radial)
90 kts
Vne
100 kts
Stall Speed
32 kts
Climb Rate @ 55-60kmts
1100ft/min
Climb Rate @480kg takeoff weight (prop dependent)
1600ft/min max
Landing Distance over 50m obstacle with 15 degrees flap and brakes applied
260m
Landing Speed (no flaps)
55 kts
Distance from takeoff to clearance of a 50m obstacle
150-250m
Hornet Specifications Data
Overall Length 6.4m
Height
2.4m
Wheel Base
2.2m
Wingspan
9m
Empty Weight
310kg*
MTOW
600kg
Motorisation
60-120hp
Design Load
+6/-3
Standard Fuel Qty
80 litres
Range standard
4 hours +
Long range tanks
80-160L
Cabin W/L/H
110cm wide
Seating
2
Engines in use: 912S Rotax, Rotax 914, Lycoming 0320
All metal airframe
Tailwheel
XL cargo area
